Grid Map Series - How do I share or print the entire series
1604
04-08-2019 10:11 AM
MichaelEagan
I set up a Grid Map Series and it covers over 8 miles and 85 separate Grids. Do I have to share/print each one independently or is there a method to share/print the entire set? I tried going to Layout/Print/All only the layout showing prints. Even if I select all of the Grids in the Contents Page.
TomBole
Hi Michael,
Currently, the best way to share a map series is by exporting the map series to a file (ex: PDF). Here is the help topic if you need additional information - https://pro.arcgis.com/en/pro-app/help/layouts/export-options.htm. The ability to print a map series using ArcGIS Pro is still being worked on. The workaround here is to export to PDF and then print the PDF.
Hope this helps,
Tom
