Grid Distance/Azimuth converted to Ground Distance/Azimuth
1988
7
08-03-2022 09:51 AM
TylerT
Hello,
I have drawn a line in a specified state plane coordinate system map and feature class.  Now I would like to label/report the ground distance and azimuth of this line.  Is there a stock geoprocessing tool for calculating grid to ground distances and directions?
Thank you.
Tyler
DanLee
by Esri Regular Contributor
TylerT
I'm not seeing a ground distance parameter in that tool.  Am I missing something?  Thx.  Tyler
DanLee
It seems you drew the line in state plane coordinate system; the Shape_Length of the line should be the ground distance. Otherwise, I am not sure what you meant by ground distance.
TylerT
The line is in Grid Distance (ie. State Plane Coordinates).   I need to report back ground distance or what we would actually measure on the ground.
TylerT
I could calculate it, but it's safer to use a tool that's been developed and QC'd.  I'm just not seeing any tools at first glance.
DanLee
I checked with our 3d team member. He said:
"The Add Surface Information tool has a Surface Length option. If the input geometry is already 3D the Add Z Information tool has a 3D Length option."
https://pro.arcgis.com/en/pro-app/latest/tool-reference/3d-analyst/add-surface-information.htm
https://pro.arcgis.com/en/pro-app/latest/tool-reference/3d-analyst/add-z-information.htm
TylerT
Thx.  I'll look into these. Tyler
