Google photorealistic 3d tiles to Scene
3469
12
06-11-2024 04:38 AM
Calls
Hello, I am trying to add google's photorealistic 3d tiles to Scene, using ArcGIS Pro 3.30.
Photorealistic 3D Tiles  |  Google Maps Tile API  |  Google for Developers
This is the javascript api call -
https://tile.googleapis.com/v1/3dtiles/root.json?key=[YOUR API KEY]
I would like to add the tiles then publish a hosted scene layer. Is this tileset supported?
johnbrosowsky
Got it, thanks for checking into that Andrew!!
JB
Geoeki
Hey @Andrew--Johnson just came across your blog post where you mentioned "Take advantage of exploratory 3D analysis tools like line of sight or viewshed, and make temporary modifications by clipping or replacing parts of the mesh". Is this modifications functionality (clipping, masking,...) only available via ArcGIS Pro, or also via a Web Scene when part of a custom JS API app? Just a bit confused why that's only doable via Pro. Thanks!
Andrew--Johnson
Different clients have different priorities and release dates so it's not guaranteed that functionality that exists in ArcGIS Pro is going to be present in the Scene Viewer. I would add an ArcGIS Idea or post in the ArcGIS Online community so you can get better updates from the Scene Viewer team on that functionality.
thanks,
Andrew
