Go to X,Y Qustion for 3D in ArcGIS Pro 2.4.1
893
08-23-2019 09:34 AM
DEAF_PROBERT_68
Honored Contributor
When you are in ArcGIS Pro and You convert your Map to 3D  and if you need to use the GO to X, Y to ensure it goes to the right spot.
I have convert my map to 3D and use Go to X, Y to ensure the Long and Lat are correct.
The problem is when the Green "ballon" is at the top instead of at the ground.
Is there a way for me to get the Green "Ballon" to get it to the ground ?
I have set the layers in the Elevation to the ground/surface .
Is there something am I missing here ?
DanPatterson_Retired
DEAF_PROBERT_68
Honored Contributor
Thank you ! I will read it and toying it around ...
DEAF_PROBERT_68
Honored Contributor
Thank you. That help !  The position settings for 3D is tricky to find it there.
