Getting Height value of vertices in a polyline
3265
8
11-26-2021 03:23 AM
matu89
hey,
i made a polyline that has 29 vertices i want to get the height value for each vertex..
is there a way to do that ?
see image attached:
thanks.
LeePenney
Do you have a raster with elevation data handy? If so, you can use the following workflow:
1. Run the Feature Vertices to Points tool. This will give you a new point layer to work with.
2. Run the Extract Values to Points tool on your new point layer and use your elevation raster. This will create yet another new feature layer. These new points will have the elevation data in their attribute table and you can calculate away!
The disadvantage of this is that your original line layer will not have the point info itself, but you can probably link the information somehow through Spatial Join or some other table-based operation.
DanPatterson
MVP Esteemed Contributor
two solutions here
Solved: Trying to access coordinates of the vertices in po... - Esri Community
just add
pnt.Z
to the geometry properties needed
... sort of retired...
matu89
I'm a bit confused..
Where do I need to paste this code ?
Do I need first to create a new feild ?
I think first I need to see 29 lines of my vertices in the attribute table no?
Thanks..
DanPatterson
putting the z values in a table wouldn't be an option, the suggestions produce a new file.
What do you want to do with the Z values?
matu89
What do u mean by producing a new file?
It creates a new feature class ?
How do I execute the code ?
Eventually I want to list those z values inside the attribute table (if it's possible) and make a calculations with them...
LeePenney
matu89
Thanks!
it works!
DanPatterson
sjones_esriau
You can also look at the Geometry tab in the attributes pane to quickly review vertex Z values.
