In ArcMap when you point on any data in the catalog you can copy the full path from the "Location" at the top of the catalog.
This is very useful when you put the file path in scripts, work documents or emails.
I could not find an easy way to do it in Pro.
The best way is to drag the data into the python window - it put the full path.
You can drag it into the map and then open properties and copy the path and then the name.
When you point on the data you get a popup with the full path but you cannot copy it.
Any other idea?
I see. In catalog view, after selecting an object > Manage > Copy Path (see screenshot)
They should put it for the catalog pane and not only view but this is fine too.
