Hello All,
I have begun the process of Georeferencing Plats of Survey for our parcels. However, when I try to 'Move', 'Scale', and/or 'Rotate' the plat in Pro it disappears from view.
I can load the Plat of Survey into Pro just fine (see attachment '1_LoadedPlat') but after setting SRS and then activating the 'Move' command from the 'Prepare' group the Plat disappears (see attachment '2_LoadedPlat'). I can get the plat to reappear if I click 'Add Control Points' from the 'Adjust' group (see attachment '3_AddControlPoints') but if I select the 'Move', 'Scale', and/or 'Rotate the plat will disappear again.
Any help would be greatly appreciated!
FYI: I have tried this in both version 2.9.3 and 3.0.1. I have also tried using a PDF > Export to TIFF and PDF > export to PNG
