Geoprocessing Service with output Feature Layer
2767
05-19-2023 10:43 AM
Labels (2)
JillianStanford
Hello!
I am trying to successfully return a feature layer as the output of the GP service and having absolutely no luck.
I have a very simple python toolbox tool with the following output parameter:
out_features = arcpy.Parameter(
            displayName="Output Features",
            name="out_features",
            datatype="GPFeatureRecordSetLayer",
            parameterType="Derived",
            direction="Output")
        return [out_features]
The main code block looks like this:
def execute(self, parameters, messages):
        """The source code of the tool."""
        inFeatures = r"D:\Projects\OCTA\LODES\data\Test_GP_Service\Test_GP_Service.gdb\Parcels_SaltLakeSub"
        out_fc = arcpy.CreateScratchName("out_features",
                                        data_type="FeatureClass",
                                        workspace=arcpy.env.scratchGDB)
        out_fc = arcpy.analysis.Buffer(inFeatures, out_fc, 100).getOutput(0)
        arcpy.AddMessage(out_fc)
        #parameters[0].value = out_fc
        arcpy.SetParameter(0, out_fc)
        return
I'm able to execute the tool successfully and publish the results to a standalone ArcGIS Server.
When I submit the job, the logs say that everything was executed successfully and the feature class in scratch.gdb in the related arcgisjobs folder looks correct on the server.
However, when I try and view the contents of the output either using the REST endpoint by submitting a job using Javascript, it is always empty.
Somehow, I'm not setting up the output parameter correctly but I can't figure out the trick.
Any ideas are greatly appreciated.
Thanks!
Jill
Tags (1)
JillianStanford
In case it's helpful to someone else, changing the output parameter type to "DEFeatureClass" did the trick.
            datatype="DEFeatureClass",
            direction="Output")
JillianStanford
            direction="Output")
PrayagShah
Hi Jillian,
I am having the same issue that unable to see the output through javascript but on standalone it works perfectly.
I am trying to set up the Parameters through ArcGIS Pro and I do not see the option named DEFeatureClass. Do you know what name would be similar to DE Feature class?
Thank you for your time.
JillianStanford
I think it would just be a feature class - Parameter data types in a Python toolbox
