Generate List of Map Layers in ArcGIS Pro 3.2?
4075
04-12-2024 11:57 AM
jchester73
In Pro 3.2 is there a way to export a list of map layers and their layer groups? Or is Python the only way? Would like to export in order to review with others to make changes to a web map.
DanPatterson
MVP Esteemed Contributor
python
ArcGISProject—ArcGIS Pro | Documentation
with listMaps, then
Map—ArcGIS Pro | Documentation
with listLayers
and so on
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
To get a list of map views in your ArcGIS Pro project, you can use the Python code here in this Esri Community post.
To get a list of all data sources used in an ArcGIS Pro project, you can use the Python code here from the GIS Stack Exchange.
Maybe there's a way to combine the 2 scripts into 1 script.  Not sure as I'm not a Python user.
jchester73
I was able to generate a simple list with script below. Group layers were also listed as layers at the beginning of each set. Copied into Word then manually highlighted the headings. Nice if this were just a built in feature in Pro...
import arcpy
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.listMaps("Map_Name")[0]
for lyr in m.listLayers():
print(lyr.name)
Robert_LeClair
You may want to consider creating an ArcGIS Idea for this item.  The more kudos it receives the more attention it may get from the ArcGIS Pro developers!
FabioPerea
My hero!!!
