Force ArcGIS Pro to Create a New Map when I copy and paste a Layout
752
09-28-2021 12:48 AM
JohnEsther2
Hi
I want to make a map copy of the Map every time I copy paste a Layout in ArcGIS Pro. Is there a setting I need to configure for that to work. This way I can change one map at a time without modifying it for the other layouts
Regards
David_Brooks
MVP Regular Contributor
@JohnEsther2 I think this is grounds for an Idea, but for now, there is a really simple workaround.
Just share the layout as a layout file, then reimport the layout file back into your Pro project. Then the layout and associated maps get added back with a "1" tagged onto the end. Simples 🙂
David
..Maps with no limits..
DanPatterson
There is no setting, but you can check yourself in the Project backstage, under Options.  All user configurable options are there
... sort of retired...
JohnEsther2
Ooh. Thanks for the update. I thought there is something to click for that to happen
David_Brooks
David
