Font size in ArcGIS Pro when exporting to pdf
646
08-10-2021 12:04 AM
JohanBaard
Hi
In ArcGIS Pro 2.8.2 i export a pdf (150km wide area) and need to use a small font so it will be readable and not cluttering other text. 1pt is too large, but 0.1pt is not accepted (it defaults back to 1pt). I can do this in ArcMap 10.7.
Can one set a font to 0.1pt  when exporting to PDF in ArcGIS Pro?
Regards
JayantaPoddar
Could you convert the labels to annotations at a desired reference scale, as a workaround?
Think Location
JohanBaard
thx for the reply. I can try that. I thought I may just missing something.
Regards
CraigWilliams
You also don't need to convert labels to annotation to benefit from the reference scale. You can just set one in the map itself.
