Finding overlapping parts of two line feature classes
4775
11-28-2023 05:28 AM
emazan
I work in ArcGIS Pro, and I have two line feature classes where I want to find all overlapping segments. The feature classes take up the same geometric space for an unknown length every time they overlap, but the overlap is not necessarily feature by feature. I’ve tried to show different types of overlap in the image. The blue feature class covers the whole line network, whereas the red feature class covers parts of it. There are also other feature classes (black) that cover the whole network. What I want is the green lines.
I’ve tried joins and doing different select feature by location analysis, but the result is not correct. My problem I think is that the features in the different feature classes have different lengths and starting/ending points, and so the result will show me features that partially overlap. But I want only the overlapping segments.
It doesn’t matter if I have to cut, erase or save results in a different feature class. In the end I’m only interested in the total length of the overlap.
I hope somebody has a solution and that I’ve made myself understood; I don’t usually express this in English!
DanPatterson
MVP Esteemed Contributor
emazan
That worked. Thank you!
MaraKaminowitz
