Field Name Truncation in ArcGIS Pro 3.1.3 GP Outputs
674
02-08-2024 07:33 AM
Jonathan_Goergen
My work unit recently upgraded from ArcGIS Pro 3.1.2 to ArcGIS Pro 3.1.3 and while updating training material created using ArcGIS Pro 3.1.2 I noticed that my field names are truncated in the outputs of geoprocessing tools.  I ran a spatial join and the results truncated the output FC (not exporting to SHP) field names to 10 characters.  This did not occur in AGP 3.1.2.  Has anyone encountered this? Is there a solution rather than a work around? I do not want to alias the fields to get my original field name.  Here is a screen shot of the two input tables of the spatial join and the output table:
Jonathan_Goergen
Commenting to follow this, because this is something I've been worried about with a few of our datasets for a while now.
We have some names that are longer than 10 characters that we've had difficulty shortening without losing clarity, and when you truncate them to 10 characters, you end up with a couple dozen fields with the same name.
They're generally not included in anything we do shapefile-wise, but it's still been a concern.  If it's now an FC issue, then that's a major concern for us, and is going to drastically change my timetable on our next schema updates.
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Robert A. Heinlein, in Time Enough for Love
Jonathan_Goergen
I have ran it a few times and have gotten inconsistent results - I re-ran and it worked as expected, I am going to test a few times because I need to know what will happen when I run trainees through an exercise next week
Jonathan_Goergen
I was exporting to a non-project GDB and selected the GDB in the file chooser and typed my file name rather than clicking into the GDB so the file was exported as a shapefile - no problem here
Jonathan_Goergen
User error
