Hi everyone. Error 160506. Failed to execute rename. The data owner of the FD cannot rename feature classes. The data owner has advance license.
How are you renaming?
Any other details would help
try to rename gisdb."GOVCY\ZZOMENI".GeologicalSuitabilityZones to gisdb."GOVCY\ZZOMENI".GeologicalSuitabilityZonesJan2020
We use this procedure:
right-click the feature class in the Catalog pane, click Rename, and type a new name
try renaming the last bit as
GeolSuitabilityZonesJan2020
I remember something about not exceeding 32 characters, but I can't find it
It's actually a 31-character limit (buffer is size 32, including the terminating NUL character).
Aliases can go to 64 characters, but the name must still be < 32.
Note that the above was from before 10.8, so it depends on the release level of the
enterprise geodatabase.
- V
Here is the information on naming limits: https://pro.arcgis.com/en/pro-app/help/data/geodatabases/manage-sql-server/enterprise-geodatabase-li...
The length does not look like an issue.
Is there another ArcGIS client (Desktop / Server / Enterprise / etc.) connected to that table?
Are there any other locks on the table?
try compressing the geodatabase to state zero first
