I am attempting to export a PNG image file from ArcGIS Pro 1.2.0 with the background set to transparent. In ArcMap 10.3 this is simple, there was a button for setting the transparent color to white during the export.
When I go to "share" the image in ArcGIS Pro, I do not see the same options to set my background or transparent color. Has this button been moved elsewhere? Or is it not an option anymore?
Another possible work-around, convert feature to graphic, select and group all attributes, then simply copy and paste (will result in a .png with translucent background) Not a method I am particularly proud of, but it works for fast and easy workarounds :)
