Exporting from Map Service to File GDB in Pro
820
03-16-2022 01:18 PM
hherrmann_coj
Hello.  I am using a map service for parcels from the County of the municipal organization that I work for.  Once I added "data from path", I was able to select by attribute but I'm not able to export the selected parcels into my working file GDB.  The only thing I was able to do was "create layer from selected" which still points back to feature service and the data/export data option is grayed out.  Is there not a way to do this in Pro?
George_Thompson
Esri Notable Contributor
The service owner may not have Extract enabled. You could try the Feature Class to Feature Class GP tool.
--- George T.
hherrmann_coj
Sadly that didn't work either.  There doesn't seem to be a way to export from a feature service.  At least that I have been able to find in Pro yet.
George_Thompson
Is the Extract operation on the service enabled?
--- George T.
