Exporting a pipe line out of Line feature in ArcGIS Pro
2609
01-20-2016 01:34 AM
Arun_PrasadRamanujadoss
New Contributor III
Hi Friends!!
     I am in need of creating a pipe line from a line feature. But, using Export feature in Appearance tab, I only have options to extrude as a wall. It is comimg just like a wall.
I have diameter of the conduit. Is there any options to create a circular pipeline from the line feature?????
MervynLotter
Hi Arun
You should use the Buffer 3D tool and then specify buffer width based on
diameter. It works on point or line features.
Regards
Mervyn
On 20 January 2016 at 11:34, Arun Prasad Ramanujadoss <geonet@esri.com>
MervynLotter
Hi Arun
Regards
Mervyn
New Contributor III
Thanks a lot Mervyn. The exact tool I wanted. Worked like a charm.
