Export photos stored in geodatabase
3155
6
08-08-2023 02:56 PM
GregZartman
I have a geodatabase in AGOL that I created for data collection using field maps.  One of the feature classes is a point class with data and photo attachments taken in the field.  Is there a way to export some sort of table, report, etc that would include the data in the database along with the photo associated with the data?
swfbtucs
I created a python script that exports the images and gives them a filename associated with an attribute field value. It's not a report, but it certainly helped out with the several thousand points we had and the several images attached to each point. You might be able to use it as a basis for a script that actually would write the file names to a delimited text file.
RachelManagh
Could you please post the python script? I am having the same issue as above.
ReNaeNowicki
I apologize. I no longer have access to the script.
BobbyS
Hello!  "swfbtucs", you mention you created a script to do this...is it posted?  I am also confused as to why someone named "ReNaeNowicki" commented that they do not have access to the script?  ReNaeNowicki is not who was asked for the script.
Does anyone have this script or something similar?  I am very interested and not sure why there are not more resources out there to address the simple task of dumping out photos from a featureclass to a folder.
AndreasHall
If you just want to dump out the photos you should try this new tool: Export Attachments (Data Management)—ArcGIS Pro | Documentation
AndreasHall
Have you tried the report functionality in Pro?
Reports in ArcGIS Pro—ArcGIS Pro | Documentation
