Trying to print this layout which is sized at 34"x44" (ANSI E) within ArcGIS Pro 2.8.3.
But when using Export Layout to a PDF on a local drive using default settings, my PDF looks like this:
When my coworker does the same at ArcGIS Pro 2.6.x using a project package I exported, it prints without issue and looks as expected. Can anyone confirm whether this is a bug with 2.8.x?
Is it possible you have a map series enabled on your layout? That's the only reason I can think of for the extent changing.
Thanks for the response on this. Nope, map series is disabled.
That's really odd. I've never seen anything like it, it looks like a bug. I would recommend reaching out to tech support, as they can take your case and get it to the appropriate development team to fix. https://support.esri.com/en/contact-tech-support
Was there ever a fix for this? I am having this problem with every layout that I print to PDF and its driving me crazy
