Export labels "export to cad" arcgispro
2884
01-02-2020 11:25 AM
AmyMorgan2
How can I export labels when exporting to CAD when using ArcGisPro 2.4?
Robert_LeClair
Esri Notable Contributor
Since labels are derived from the attribute table of a feature class, I would recommend you follow the following workflow for ArcMap but try it in ArcGIS Pro.  Is the result the same?  Please advise.
AdrianWelsh
MVP Honored Contributor
Hey Robert, I just tried this with no luck.
TadeášDěd
New Contributor III
this tutorial works only for points - https://desktop.arcgis.com/en/arcmap/10.3/manage-data/cad/exporting-attributes-as-cad-text.htm
The best way I came across is to export the feature layer with created annotation:https://support.esri.com/en/Technical-Article/000008383
Best
T.
