Export labels "export to cad" arcgispro
5192
01-02-2020 11:25 AM
AmyMorgan2
How can I export labels when exporting to CAD when using ArcGisPro 2.4?
Robert_LeClair
Esri Esteemed Contributor
Since labels are derived from the attribute table of a feature class, I would recommend you follow the following workflow for ArcMap but try it in ArcGIS Pro.  Is the result the same?  Please advise.
AdrianWelsh
MVP Honored Contributor
Hey Robert, I just tried this with no luck.
TadeášDěd
this tutorial works only for points - https://desktop.arcgis.com/en/arcmap/10.3/manage-data/cad/exporting-attributes-as-cad-text.htm
The best way I came across is to export the feature layer with created annotation:https://support.esri.com/en/Technical-Article/000008383
Best
T.
JuliusP
Has been there any improvements to this? Higher Ed contracts can no longer get ArcMap from Esri so we are stuck with using ArcGIS Pro... but as far as v3.3.2 we still cannot include Annotation feature classes when running the Export to CAD tool.
Has anyone gotten any success in including labels to CAD using ArcGIS Pro?
