Export attribute table from ArcGIS Pro to Excel
446
09-21-2021 11:12 PM
RichardKoech
Some help please, I have wasted 2 hrs trying to figure out.
How can I export data in attribute table in Pro to Excel?
Thanks.
AndreasLorentzen
This is easily done with the tool: Table To Excel (Conversion)—ArcGIS Pro | Documentation
Note that it only export the current selection if you drag it from an active map.
Also as a side note, you could ofc. use arcpy with pandas if you would like to make your own tool with specified output.
RobertBorchert
Frequent Contributor III
A really slick part is you can also export the table using the Alias as the column header and you can populate subtypes and domained values with the Description rather than the code.
