Error of create network dataset
781
10-05-2022 07:47 PM
LixiaonaYu
When I am doing the tutorial of Create a newtowk dataset, I get this error and cannot create the network dataset.
ERROR 030222: The network dataset cannot be created from the given parameters.
DanPatterson
You didn't show the rest of the errors, but I suspect it is
160492: The network source participates in multiple network datasets.—ArcGIS Pro | Documentation
Which notes...
Note:
While this error can occur, it occurs so rarely that the typical causes have not been identified so no solution is available at this time.
So you will have to contact Tech Support.
There is something wrong with the inputs to the tool
... sort of retired...
CongyingHu
I came across this problem as well. Can't believe it is still unresolved after 1 year.
