Error 999999 while calculating Zonal Statistics as Table for 300k features
913
11-30-2020 07:34 PM
BraundtLau
Am running zonal statistics as table for overlapping polygons, and my original dataset has 320k buffers.
I've already changed my raster processing extent to >65k, and also made sure the projection is the same for all features, but still Error 999999 occurs.
Furthermore the script works alright on a polygon dataset of 45k features but now with this larger dataset i run into issues.
Also the tool doesnt just give me the error right away- i've tested multiple times and usually it happens after running for 1 or 2 hours - which is very frustrating.
The code is as below -
def calZonalStat(gdb, buffers, in_ras,name):
    #pcd = postcodes
    now = datetime.datetime.now()
    print("Start_time: "+ str(now))
    #code
    out_table = gdb + name+"_ztbl"+appx
    ztbl = arcpy.ia.ZonalStatisticsAsTable(in_zone_data=buffers, zone_field="pcd", in_value_raster=in_ras, out_table=out_table, ignore_nodata="DATA", statistics_type="ALL", process_as_multidimensional="CURRENT_SLICE", percentile_values=[100])
    #end time
    later = datetime.datetime.now()
    elapsed = later - now
    print("End_time: "+str(later))
    print("calZonalStat time: " + str(elapsed))
    return ztbl
Air_PM25_RC_ztbl_al1= calZonalStat(loc_gdb, buffers_al1, Air_PM25_RC, 'Air_PM25_RC')
And here's the error message
# Start_time: 2020-11-25 13:46:12.085096
# Traceback (most recent call last):
#   File "<string>", line 1, in <module>
#   File "<string>", line 8, in calZonalStat
#   File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\ia\Functions.py", line 3956, in ZonalStatisticsAsTable
#     percentile_values)
#   File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\sa\Utils.py", line 53, in swapper
#     result = wrapper(*args, **kwargs)
#   File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\ia\Functions.py", line 3946, in Wrapper
#   File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 511, in <lambda>
#     return lambda *args: val(*gp_fixargs(args, True))
# arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
# Failed to execute (ZonalStatisticsAsTable).
Am wondering if it might be because of limited memory? in my C drive there's only 15GB out of my 100GB SSD. Or any other ways to speed up the process?
Any advice would be appreciated - Thanks!!!!!
DavidPike
MVP Frequent Contributor
You might need to calculate statistics on your input raster for it to run the percentiles (just a guess). I'd also check your raster has integer values not float.
also not sure where appx (above) is as a parameter.
I'd recommend running the tool manually with those parameters on a subset of your data to narrow-down the issue.
Taren_Esri
Hello,
Here (https://support.esri.com/en/Technical-Article/000015210) is an article that addresses common Zonal Statistics as Table error causes. I would absolutely recommend running check/repair geometry, then moving onto the other troubleshooting options.
gisgis2
It could also be that there is no surface from the vector layer in the raster overlay, in which case it is a formal error of the Zonal Statistics as Table tool.
If working with an arcpy script, "try - except" is used so that the calculation is not interrupted.
Otherwise, errors in the geometry of the vector layer should be looked at and possibly corrected with the Repair Geometry tool.
