Error 001904: SDE or DBMS admin user cannot create a utility network
4255
12
05-22-2018 01:45 PM
BryceGardner2
I am trying to learn about Utility Network and keep getting this error.
I first tried with my OS authenticated user. No dice, should've read closer.
Then I tried with our SDE user that I set up as the geodatabase owner. No dice.
I asked our DBA to create an user in SQL that is database authenticated for this specific purpose. No dice. I feel like I'm stuck.
Asrujit_SenGupta
MVP Regular Contributor
Have you checked this and made sure that you are following all the other Pre-requisites: Create a utility network—ArcGIS Pro | ArcGIS Desktop
BryceGardner2
Thanks for your reply, Asrujit!
Yes, I meet all the other pre-requisites.
AbhijeetKulkarni
You need to create another user using 'create database user' with roles option just empty.  You can create Utility network with that user. SDE and DBMS cant create Utility network and that's by design.
BryceGardner2
Error Creating database user. Must be connected as database system admin/superuser
Thanks for your response, Abhijeet!
Catalog won't let me do that currently. It gives me this error:
Asrujit_SenGupta
Need to connect as SYS to create a new user.
AbhijeetKulkarni
Sorry for not being specific. Input data connection should be of DBMS user. You need to create one DB connection using DBMS user and use it while creating new user.
pragyasrivastava
Higher Education Instruction and Research
ArcGIS Pro
Hi! I am getting the same error [Error 001904] after running 'Create Utility Network' tool. Though I was able to create a new user using 'Create Database User' as suggested by Abhijeet, I am still getting same error [Error 001904] after running 'Create Utility Network' tool again. I am so stuck!! Any other suggestions on this issue will be much appreciated. Thanks!
AbhijeetKulkarni
Hi Pragya,
Can you please share screenshots of steps during 'create database user' and 'create Utility Network' tool?
Also please let us know the PRO version you are using e.g. 2.1.2 or 2.1.3 or any other.
pragyasrivastava
Hi Abhijeet!
Thanks for getting back to me. I am using ArcPro 2.1.3 and SQL server Express v17.7.
Below is the screenshot of settings that worked fine for Create Database User. Though when 'Create Operating System Authenticated User' box is checked, it asks for an existing user.
I tried to uncheck 'Create Operating System Authenticated User' box and tried to run this tool again to create a new user and this worked fine too. Below is the screenshot:
I tried to run 'Create Utility Network' tool before and after creating a new user, but getting the same error:
Thanks!
