Looking for suggestions on editing a CAD converted dataset we've received. All of the polygons that contain holes in them (donut), the holes are connected with a line to the exterior polygon something like the image below. In other words, these are a single part, and not a multipart polygon.
Is there a workflow/tool to easily update or fix these so they are a true multipart polygons?
I do understand that the following would work:
But that's not a very appealing thought for editing 1000's of these bad polygons.
Thanks for any tips/suggestions
Buffer the polygons by a tiny amount, say 0.1 feet. If those lines are contiguous, it'll "erase" them. And if the 0.1 feet mattered, then do a second buffer of the same amount, but negative.
Edit: adding images.
Original shapes:
0.1 ft buffer:
Hooray!
Try this:
- Feature To Point with INSIDE option to produce "label points" that carry the original polygon attributes. Call it Label_pts.
- Polygon To Line on the polygons with default option; call the output Lines.
- Select Layer By Attributes to select from Lines with Left_FID = Right_FID; these are the interior lines.
- Delete Features to delete the selected from Lines.
- Feature To Polygon using Lines and Label_pts, uncheck "Preserve attributes", to reconstruct polygon and retrieve the attributes.
Original shapes:
0.1 ft buffer:
Hooray!
Thanks Josh, that worked perfectly!
