dynamic text LINK tags stuck in blue font color
3307
10-21-2024 04:21 PM
CRose
In my map layout, I have a large block of dynamic text containing a list of sources, with their DOI hyperlinks.
The urls are placed within <LINK> tags to facilitate accessibility tagging.
However, the text within the LINK tag is blue and I am not able to change it to any other color.
Here's an example of a section of my dynamic text:
</FNT>Syverson, K.M., and Colgan, P.M., 2011, The Quaternary of Wisconsin: an updated review of stratigraphy, glacial history and landforms, <FNT style="Italic">in</FNT> Ehlers, J., Gibbard, P.L., and Hughes, P.D., eds., Quaternary Glaciations — Extent and Chronology: a closer look: Amsterdam, Elsevier, Developments in Quaternary Science, v. 15, p. 537–552, <LINK url="https://doi.org/10.1016/B978-0-444-53447-7.00042-8">https://doi.org/10.1016/B978-0-444-53447-7.00042-8</LINK>.</FNT>
I have ArcGIS Pro 3.3.2
CRose
Yes, I'm comfortable using formatting tags.
I have tried the CLR tag before, but without success; that may be because I tried only black.
Following your example, I am able to use the CLR tag inside of the LINK tag to change to red="230" green="0" blue="0" or any other color where one of the three numbers is greater than zero. When I use red="0" green="0" blue="0" (trying to get the text to turn black), it has no effect and the text remains blue.
With a bit more poking around, I found that if I define the color in CMYK instead of in RGB, I can use <CLR black="100"> and that seems to work okay.
Thank you for your help.
TomBole
Hi @CRose
Blue is the standard default color for hyperlinks. When a hyperlink is detected the text's color will be automatically set to blue. Currently, there is no way to change the color of the hyperlink through the UI.
If you are comfortable with formatting tags you can adjust the font color of the hyperlink text in the tag view of the Text Element pane. Any change here will not affect the blue color of the underline seen when hovering the mouse over the hyperlink. The screenshot below shows an example.
Unless you a very comfortable with using (and troubleshooting) formatting tags I would recommend sticking with the default blue.
Tom
CRose
ZacharyUhlmann1
Wanted to mention that Tom's suggestion worked, and there is an ESRI How To page mirroring his response.  Also, the blue highlighting auto-applies to dynamic text for paths/to/layouts, etc. (so not just URLs, but local drives).  I was able to apply this to a dynamic tag for the path/to/defaultFolder to remove the auto-blue.
<UND>Path:</UND> <CLR red="205" blue="205" green="205"><dyn type="project" property="defaultFolder"/></CLR><UND> Layout:</UND>
