Dynamic Field of Calculate Geometry for other Projection System
646
05-02-2023 05:24 AM
Cyprus_Forest_Department
Hi to all.
I want to create an area field of another projection system than the one my polygon layer uses.
This is possible but the created field is static.
The functionality I need is for the field to be updated automatically upon geometry edits.
Is this possible?
Thanks a lot.
DavidPike
MVP Notable Contributor
What you want is an attribute rule https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/an-overview-of-attribute-ru...
Unfortunately.. I believe the data must be Web Mercator or WGS84 for the Arcade method required https://developers.arcgis.com/arcade/function-reference/geometry_functions/#areageodetic
