Domain descriptions not showing in Arcade labels
5329
6
08-28-2018 09:41 AM
Zeke
Honored Contributor
I have a field that has a domain. The domain description shows in the attribute table, but not in labels, where the coded value is displayed. I have the check box 'Insert fields with coded value description function' checked.
Details:
Code snip
lbl = $feature["L4STRUCTURES.structure_name"] + "\n"
lbl += "Size: " + Text($feature["L4STRUCTURES.structure_size"])
lbl += "\n" + round($feature["L4STRUCTURES.lat"], 6) + ", " + round($feature["L4STRUCTURES.long"], 6) + "\n"‍‍‍
ArcGIS Pro 2.2.1
L4STRUCTURES is a feature class residing on a client's ArcGIS server, and is joined to another feature class from the same source and a local table.
Any idea how to get the descriptions to display? Thanks.
KenBuja
MVP Esteemed Contributor
To show the domain descriptions, you have to use
DomainName($feature, 'theField');
KenBuja
Zeke
Honored Contributor
Awesome, thank you! Not sure of the purpose of the coded values checkbox then, but this works perfectly. Surprised ESRI doesn't feature this more prominently.
KenBuja
When I made a simple Arcade script, just double-clicking on the field name automatically added the DomainName syntax.
Zeke
Honored Contributor
Did not do that for me. Oh well.
mrmark
Thank you sooooo much. Been fighting with this for a while. As with Greg, ArcGIS Pro (2.4.1) definitely did not help out in any fashion. Double clicking in Arcade just adds $feature.Fieldname
The only "help" I could find on Esri's site says you have to do Domain to Table, then do a one to many join of that table back to the table ...
Thanks again.
A man's feet should be planted in his country, but his eyes should survey the world. - G. Santayana
KeithAddison1
What's the Python equivalent?
