So I updated to 3.0 yesterday and I highly recommend waiting as long as you can before doing so. I am having very odd behaviors and some things simply not working like clipping a raster. Prior to updating to 3.0 yesterday afternoon, I was working on a new project, and when I updated that project no longer opened up. It has taken 3 attempts to recreate the basic portion of the project. It would just sit and spin on the FGDB and did the same thing when selecting an excel doc. I can sometimes shut down ArcPro as you normally do but at least 50% of the time I'm having to use task manager to close ArcPro. Just an FYI as this is a major release going back to 2.9.3 might cause even more problems according to ESRI documentation. Migration from ArcGIS Pro 2.x to 3.0—ArcGIS Pro | Documentation . Just a friendly PSA
Solved! Go to Solution.
Anyone else having Python problems in label expressions? Basic expressions seem to not work anymore.
I can also confirm major issues with ArcGIS Pro 3.0 update. It seams like everyday I run into another problem which wasn't an issue before. Making my job a nightmare!
- Created Project
- From the start the project Geodatabase is "Either invalid or out of date. [Invalid Geodatabase release}"
Completely broken GDB with every new project. Also had many of the same issues mentioned in the thread. Software patch please!
Hello! Sorry or reopening this discussion, but you mentioned "going back to 2.9.3" and I was wondering if that is still possible, and how to go about it?
but I wanted to ask if it is possible to go back to the previous patch of 2.9 (I think I had 2.9.5 ) after having updated to 3.0 -
I had only updated ArcGIS Pro from 2.9.5 to 3.0 because I needed the Hexagon Gridding tool, but it turns out I no longer have the Business Analyst extension (I'm a university student, so I don't know the logistics of my university's license) and I get a warning about the incompatibility of my file with 2.X updates if I proceed, so I haven't used it. I was able to get ArcGIS Pro 2.8 by following my university's instructions, but now ESRI doesn't show the upgrades available for 2.9 at all (only 3.0) and I get a similar warning regarding working on a version below 2.9.
Thank you for your time!
- Just_A_University_Student
After upgrading to 3.0 from 2.8, all of our schedule geoprocessing models will not run successfully. I can run them manually, but not if they are scheduled...
I upgraded Pro to 3.1 today and it still does not fix my scheduled geoprocessing model issue as I mentioned above.
Good to know, thanks. I rely on Python scripts running in task scheduler, so I'll keep that machine at 2.9 until this is sorted out.
