“Distribute” option appears not to be available while working in layout in ArcGIS Pro,
1168
7
11-15-2017 01:15 AM
JamalNUMAN
Legendary Contributor
I observed that the “Distribute” option appears not to be available while working in layout in ArcGIS Pro.
Jamal Numan
DanPatterson_Retired
Works for me, once I have two different things selected.
You are in the right spot, maybe not the right things or they are already aligned
XanderBakker
Esri Esteemed Contributor
The other thing I noticed is that both in ArcMap as in ArcGIS Pro the options Distribute Horizontally and Distribute Vertically are disabled, so there does not seem to be any difference in ArcMap and ArcGIS Pro.
ArcMap:
ArcGIS Pro
What type of elements are selected?
JamalNUMAN
Sorry guys for the confusion.
I wanted to say that the “distribute” option is not available in the Pro as i'm not referring to “distribute horizontally\vertically”
Jamal Numan
it is in my picture taken from Pro, it only becomes active when you select two elements that are out of alignment either horizontally and/or vertically.  Look closely, just the word Distribute is gone, the functionality is still there
XanderBakker
I think Jamal432@gmail.com is trying to explain that these options (see below) are not available in ArcGIS Pro (yet).
grief... so wrong thing circled
JamalNUMAN
This is what I wanted to say, Xander. Thank you
Jamal Numan
