“Diagram properties” for models created in ArcGIS Pro,
5141
24
09-13-2015 01:02 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to set the “Diagram properties” for models created in ArcGIS Pro,
Thank you
Best
Jamal
Jamal Numan
Robert_LeClair
Esri Notable Contributor
You're welcome - all the best!
JamalNUMAN
Hi Robert,
I observed the following:
In ArcMap, with the “top to bottom” option, the “auto layout” command arranges the tools next to each other
In Pro, with the “flip orientation” option, the “auto layout” command arranges the tools vertically which doesn’t make any sense as what’s meant with the “top to bottom” orientation is that each command will grow vertically and thus sticking the commands on top of each other doesn’t help
What do you think?
Jamal Numan
Robert_LeClair
Jamal - you need to explore the Layout options on the ModelBuilder-Diagram Group.  With Flip Orientation set in the Orientation group, click "Horizontal Sort Descending" in the Sub-Graph dropdown and then click Auto Layout.  Afterwards, you will see my AGP Modelbuilder matches your 3rd ArcMap graphic.
JamalNUMAN
Many thanks Robert. It works fine with me
I would appreciate if you could have a look on this
ArcGIS Pro 2.5: How to get the added tool to the model builder canvas aligned vertically,
Jamal Numan
Robert_LeClair
Funny you mention this - I already am working on it and have an email out to one of the AGP team today to see if I can find an answer for you.  More to come.
