Detect Objects Using Deep Learning - Parallel processing job timed out [Failed to generate table]
929
12-01-2022 04:00 AM
zou_ys
When working with deep learning models in ArcGIS Pro, attempting to run the Detect Objects Using Deep Learning tool fails and returns the following error message,when use GPU, but  not when use CPU.
Parameters
Input Raster     C:\yt\gffff.tif
Output Detected Objects     C:\Users\Administrator\Documents\ArcGIS\Projects\MyProject5\MyProject5.gdb\gffff_DetectObjectsUsingDeep10
Model Definition     C:\yt\TEST\CarDetection_USA.dlpk
Arguments     padding 20;batch_size 16;threshold 0.9;return_bboxes False;tile_size 400
Non Maximum Suppression     NMS
Confidence Score Field     Confidence
Class Value Field     Class
Max Overlap Ratio     0
Processing Mode     PROCESS_AS_MOSAICKED_IMAGE
Output Classified Raster
Environments
Processor Type     GPU
Messages
Start Time: 2022121 19:45:53
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Failed to execute (DetectObjectsUsingDeepLearning).
Failed at 2022121 19:46:00 (Elapsed Time: 6.91 seconds)
Python Command:
with arcpy.EnvManager(processorType="GPU"):
    out_classified_raster = arcpy.ia.DetectObjectsUsingDeepLearning(r"C:\yt\gffff.tif", r"C:\Users\Administrator\Documents\ArcGIS\Projects\MyProject5\MyProject5.gdb\gffff_DetectObjectsUsingDeep7", r"C:\yt\TEST\MyProjectTEST\moxing3\moxing3.emd", "padding 32;threshold 0.5;nms_overlap 0.1;batch_size 64;exclude_pad_detections True;test_time_augmentation False", "NMS", "Confidence", "Class", 0, "PROCESS_AS_MOSAICKED_IMAGE"); out_classified_raster.save(None)
PavanYadav
hello @zou_ys Are you still having this problem? What version of ArcGIS Pro are you using? If you have resolved the problem, can you share the solution? thanks
