cut fill volume
253
06-18-2021 12:51 AM
matu89
hey, i used the tool cut fill to calculate the volume between two rasters.
in the attribute table i see a volume data for each line .
first, i want to calculate the fill volumes inside the Black polygon i drew.
than, i want to summerize all the fill volumes lines .
how can i do that?
img is attached.
thanks for the help.
DanPatterson
Extract by Polygon (Spatial Analyst)—ArcGIS Pro | Documentation
if it is truly a polygon and not a polyline
... sort of retired...
matu89
thanks!
DanPatterson
If it worked, @matu89 could you Accept as Solution the thread that provided the answer.  If not, provide more details to get to the solution
