Cut Fill - attribute table
745
01-04-2021 12:30 PM
AvivitLevy
After executed Cut fill function, I have a question regarding the attribute table:
What the meaning of 'Value' in the table? in my table it contains the same values like in 'OBJECTID'
Thank you
DavidPike
MVP Frequent Contributor
The 'ObjectID' is more of a row reference in the attribute table than anything else.  Raster Attribute tables can sometimes be confusing because they look very similar to a vector (polygon etc.) attribute table, but they are just grouped summaries of the same raster cell values (e.g. 'Count' is the number of raster cells in that cut/fill 'zone'.)
So, you're right - 'Value' defines the ID given to a cut/fill group of cells (and is also the actual value of any cell within that group).
But, ObjectID doesn't define anything other than the row in the attribute table you're looking at.
DavidPike
Value is the actual coded value assigned to the raster cell(s) in the Cut/Fill region.
So say you have a fill region (row in the attribute table) of +100 volume and 'Value' of 1, all the raster cells in that region will have that value of 1.
AvivitLevy
Thank you David, so 'Value' defines the cells ID and the 'OBJECTID' defines the 'polygon' (raster) ID? what is the difference between the 2 categories in my table?
DavidPike
AvivitLevy
Ok! thank you very much
