Custom Geoprocessing registered in Portal can't be executed in ArcGIS Pro
793
07-21-2022 11:10 PM
RichardReinicke
I've created a small GeoprocessingService that pulls data from an external service and returns a GPFeatureLayer.
This way results are rendered well in Pro and I was able to publish this Service to our ArcGIS Server as private. Next I registered the service to our portal with some user providing credentials to private service => worked.
Now I open ArcGIS Pro and sign in to Portal with the same user. I see the Tool in my contents but I can't execute the tool. If I double click the tool, no form with input fields opens up, just an empty panel.
How can I troubleshoot this?
Thank you for your help!
RichardReinicke
The problem was I registered the GPService item with a url like:
/MyGpService/GPServer/MyTool
This way it also asked for credentials and created the item but following toggle-button was not active:
I had to use url of the service level item:
RichardReinicke
