Creating Map
183
02-07-2021 08:41 AM
DodaDodova
Hello, I can`t find the option for adding layers to a new layout. Where can I find this?
DanPatterson
In arcgis pro?  did you insert a map?  if so make the map tab active, then select Add Data on the ribbon.
Once you make a map then you can make a layout.
... sort of retired...
GillianElliott
Yes to what Dan said above^^
With a Layout, you can add a Map Frame. This looks to one of your maps from the project and all the layers within that map. So yes, you will need to first configure your map with all its necessary layers, then add the map into your Layout using Map Frame (Insert tab).
You can add layers into your map by using the Add Data button on the ribbon, or clicking and dragging from the Catalog.
Gillian
