Create square polygons around points
1979
05-10-2021 04:45 AM
GlenShennan
Similar to this question I would like to create polygons around all points in a layer, except instead of circles I need 50x50m squares, oriented with facing north-south, east-west. I can't use buffer because that will only create circles, but I can't figure out another approach. Any ideas?
JayantaPoddar
DanPatterson
JayantaPoddar
Hope this helps. How To: Create a square buffer around a point feature
Think Location
XavierBustos
After creating the Buffers use Feature Envelope To Polygon (Data Management)
Hope this help
Kind Regards
SergeyTolstov
See also Graphic Buffer tool. It can make a square buffer around points if you use square cap property.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/graphic-buffer.htm
