Create a road segment with only road name and to/from information
296
04-22-2020 04:23 PM
RohanSadhai
How do I create a road segment with only the road name, and to/from data, without having to physically digitize the road? I don't have xy coordinates, and several hundred segments to create. An example of the data is as follows for a road segment in Miami: 96th Street from Collins Avenue to Abbott Avenue.
DanPatterson_Retired
Have you looked see if the street maps are available from the locations you are interested in or Open Street Map?
RohanSadhai
I am using street maps as a base. I need to create specific to/from segments as a separate layer, but wanted to find out if there was an easier way to do it than to look up each location and digitize them manually.
