Create a Locator and Apply Geocode Address to Brazil
627
11-03-2021 09:50 AM
IaraNascimento
New Contributor III
I configured the address finder to use data from Brazil and it is not working. I used the <As a defined in data> parameters and the locator and the geocode address does not work.
Does anyone have the Geocoder Address configuration pattern for the Brazil address pattern? It´s so important to me, I need to finish a work
How the locator will read my data out pattern of USA? We don´t have a direction street, like in the USA.
Iara
ABishop
MVP Regular Contributor
Have you tried using the ArcGIS World Geocoding Service?  It uses credits, but could be an option?
Amanda Bishop, GISP
IaraNascimento
New Contributor III
Amanda,
I am using an ArcGIS Pro. And I want to create a geocode to not use credits. I don't want to use an ArcGIS World Geocoding in this test. I am testing a Creator Locator tool.
ABishop
Understood.  Maybe there is a geolocation setting where you could change it from the US territory to Brazil?
Amanda Bishop, GISP
ABishop
Also, I found these tutorials online that may be of assistance in adding global locations to your locator.
https://pro.arcgis.com/en/pro-app/latest/help/data/geocoding/find-places-on-the-map.htm
https://pro.arcgis.com/en/pro-app/latest/tool-reference/geocoding/create-locator.htm
Amanda Bishop, GISP
IaraNascimento
New Contributor III
Thanks, I managed to set up a create locator tool.
