Count # of occurrences in a tessellation
864
12-06-2024 02:00 PM
leahmaps
Hi all,
I have a hexagon tessellation that I am trying to get transform statistics into from a raster below (could turn the raster into polygons, based on area in acres, or pts, based on counts).
The picture below will help explain, but for each tessellation, I want to count the # of total raster cells, as well as the occurence of each value (i.e. 19 pixels, 6 orange, 9 blue, 4 yellow). Percents would be fine, too, but raw counts preferred. I have tried zonal staistics, summarize within, etc. but nothing seems to give me an output what I am looking for. Usually, things are based off mean/median/mode/etc. and is counting the no value/backround raster points. Has anyone done anything similar or have a simple workflow?
BobBooth1
leahmaps
I did try that, along with regular zonal statistics. The issue for me is that it doesn't count each thing individually, and in the case of a raster, is still counting 'no data'/background cells, even though they were deleted from the set, I wish it worked because that was what I was hoping to use!
DanPatterson
MVP Esteemed Contributor
DavidPike
MVP Notable Contributor
Possibly Tabulate Intersection tool after converting to vector.  Then divide 'Area' by the original raster cell size to get Count.
https://pro.arcgis.com/en/pro-app/3.3/tool-reference/analysis/tabulate-intersection.htm
