Hi! I have two feature classes and I need to copy (transfer) all the features from one feature class to another. The amount of feaurtes is >8000. What is the best way to transfer all the features, as the copy and paste option on Clipboard does not allow to copy huge amount of features at once.
I have included some links below which you might find helpful with your query
https://pro.arcgis.com/en/pro-app/latest/help/editing/copy-and-paste-using-the-clipboard.htm
@LIEPAJABUILDINGBOARD, copy-paste (special) ideally should work. However, the best approach I can think is Append. You can use Append geoprocessing tool.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/append.htm
Steps:
In ArcGIS Pro, click "Analysis" in the ribbon >> Tools
Geoprocessing window will popup. Search "Append"
Open Append (Data Management)
In the tool:
Input Dataset:The input datasets containing the data to be appended to the target dataset.
Target Dataset: The existing dataset where the data of the input datasets will be appended.
< If schema of your input and output dataset matches>
Field Matching Type: Input fields must match target fields
Otherwise, choose field mapping option.
Rest all, parameters are optional & depends on your requirement.
Hope this helps! Thank you 🙂
