Copying huge amount of features (>1000) from one feature class to another
169
07-31-2024 11:23 PM
LIEPAJABUILDINGBOARD
Hi! I have two feature classes and I need to copy (transfer) all the features from one feature class to another. The amount of feaurtes is >8000. What is the best way to transfer all the features, as the copy and paste option on Clipboard does not allow to copy huge amount of features at once.
GeeteshSingh07
Occasional Contributor II
@LIEPAJABUILDINGBOARD, copy-paste (special) ideally should work. However, the best approach I can think is Append. You can use Append geoprocessing tool.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/append.htm
Steps:
In ArcGIS Pro, click "Analysis" in the ribbon >>  Tools
Geoprocessing window will popup. Search "Append"
Open Append (Data Management)
In the tool:
Input Dataset:The input datasets containing the data to be appended to the target dataset.
Target Dataset: The existing dataset where the data of the input datasets will be appended.
< If schema of your input and output dataset matches>
Field Matching Type: Input fields must match target fields
Otherwise, choose field mapping option.
Rest all, parameters are optional & depends on your requirement.
Hope this helps! Thank you 🙂
