CopyFeatures not recognizing selected features in arcPy script
744
11-30-2021 01:03 PM
PhilCrossley1
Hi. Have appreciated past help.
I'm trying to incorporate an attribute query into an arcpy script, and then work with the results of that query in a subsequent for: loop.
The script snippet below successfully creates the Indiana folder and GDB, and selects the Indiana counties, and creates a new INcounties feature class, as intended, BUT the new feature class includes ALL the US counties, not just the selected IN counties.
would appreciate any suggestions!
arcpy.CreateFolder_management(r"E:\advAppScripting\testing\tornhazard", "Indiana")
arcpy.CreateFileGDB_management(r"E:\advAppScripting\testing\tornhazard\Indiana", "IN_data")
arcpy.SelectLayerByAttribute_management("counties.dbf", "NEW_SELECTION",
""""STATE_NAME" = 'Indiana'""")
arcpy.CopyFeatures_management(r"E:\advAppScripting\testing\tornhazard\counties_layer",
r"E:\advAppScripting\testing\tornhazard\Indiana\IN_data.gdb\INcounties")
DanPatterson
Select Layer By Attribute (Data Management)—ArcGIS Pro | Documentation
you may need to make a layer or table view first since it is apparently just copying counties_layer over without any selection
arcpy.management.SelectLayerByAttribute(in_layer_or_view, {selection_type}, {where_clause}, {invert_where_clause})
... sort of retired...
DanPatterson
PhilCrossley1
had been trying to find a way to add a tool parameter, or a step in btw. the selection and the copy Features, but you're right (as I've come to expect!):  when I run MakeFeatureLayer first, to create a counties_lyr, then run the query and the copyFeatures (set to export the (selected features in the) counties _lyr), it works exactly as intended...I don't think the Pro help files makes the need to follow this order of operations clear at all!  I sure appreciate the quick, and helpful, help!
DanPatterson
No problem Phil.  I have a preference to use the Python tab out of the Dialog Python under Parameters... there is often more information there and the parameter specification tends to be clearer (to me at least)
