Convert tif+tfwx to geotiff
2196
09-20-2021 04:51 AM
RobertoRossi
I'm looking for a workflow to convert some hundreds files from tif+tfwx+xml to geotif, without changing the input properties (the input files have different jpeg compression values), which I must leave unchanged (they are georeferenced cartographies).
I built a Model with Copy raster with the Apply transformation option, but the output honors the compression value, which i don't want to set (I would like it corresponds to the input value).
Essentially I'm looking for some tools which just turns the tif to geotif without changing any characteristic of the input file.
David_Brooks
MVP Regular Contributor
@RobertoRossi I would use https://github.com/OSGeo/libgeotiff
The geotifcp tool can write the world file into the header of the TIFF to make a GeoTIFF
David
..Maps with no limits..
RobertoRossi
Thankyou @David_Brooks (David) , I'll try to understand how to use this library
RobertoRossi
Sorry, David,
how should I use the geotifcp tool?
I found the code in github but i didn't understand how to use it: does it work inside ArcGIS Pro? Do I need to install Visual Studio?
