Convert 13 digit date to proper date format (DD/MM/YYYY)
273
08-28-2021 11:47 AM
JasonBenedict
New Contributor II
Hello,
I have a numeric field that represents dates in an attribute table that contains 13 digits (e.g 1457222400000). I have seen a few posts like this on converting this to dates if it's in 5 digits but not a number with this many digits.
Is there an easy way I convert this to a proper date format using the field calculator or Arcpy?
Many thanks in advance!
Jason
KenBuja
MVP Honored Contributor
You'll also want to use the Text function to properly format the date.
Text(Date($feature.dateFieldname), 'D/M/Y')
DavidPike
MVP Frequent Contributor
If that's a Unix millisecond timestamp I think you can just field calculate with Arcade using
KenBuja
