Configure html pop up to show actual link
724
07-31-2018 12:52 PM
Zeke
Regular Contributor III
I have a pop up configured in a web map that links to pdfs. Click the link, pdf displays. All good.
However, the link in the pop up is 'More Info'. I'd like it to display the actual link, i.e. http://somesite/somepdf.pdf while still linking.Is this possible, and if so, how? Thanks.
CarmelConnolly
Hi Greg,
You can do this through the use of Custom Attribute Displays in the layer's Configure Pop Up option. This blog covers it really well: Crafting custom attribute displays in pop-ups
The section called 'Adding links from fields' will cover what you're looking for, but you'll use the same field name for the URL and the Description, similar to this:
Carmel
CarmelConnolly
Hi Greg,
Carmel
Zeke
Thanks Carmel, that worked perfectly.Much appreciated.
