Clipping by individual feature
1396
01-27-2023 01:46 PM
Mktrz08
I need to calculate impervious surface area of ~300 polygons. I have one layer that contains the polygons, and another that has the impervious surfaces (also polygons, that overlap my 300 polygons). I basically need to clip the impervious surface layer to the 300 individual polygons vs clipping to the full extent of the layer so i can then calculate the area.
I feel like I'm just blanking on something obvious here..
In the image, the lime green polygons are the polygons I need to measure impervious surface for. The olive green is the impervious surface layer.
DanPatterson
MVP Esteemed Contributor
clip supports the Extent properties in the Environments tab
Extent (Environment setting)—ArcGIS Pro | Documentation
have you checked that out?
Clip layers in a map—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
Mktrz08
That did it! Thank you so much!
