Clip Raster with Polygon Freezes ArcGIS.
3410
12-28-2020 07:37 AM
by Anonymous User
Not applicable
I have a GeoTIFF I downloaded from LidarExplorer (both 10m and 30m) which I want to clip with a polygon shape (Boundary of Mt. St. Helens Volcanic Monument).  Every time I do this ArcGIS freezes the panels but not the Map view.  The little blue balls keep dancing at the top of the Clip Properties panel.  I've ran it overnight and the only way to stop it is to end the process under Windows.  I've used the same raster and shape and successfully cut the raster in QGIS.  I can cut raster with window extent without problem (I use a cut down raster in attached image).
Thanks in advance,
Mats
SteveLynch
Have you tried using the ExtractByMask geoprocessing tool?
SteveLynch
by Anonymous User
Not applicable
That's brilliant Steve!!!
Thank you so much,
Mats
bcdi
Yeah Steve Extract by Mask is amazing 🤣
