Clip layers to shape extent ArcGIS Pro
22458
32
07-02-2015 04:27 PM
GregStevenson
New Contributor III
Has anyone had experience clipping layers to the extent of a shape in ArcGIS Pro?
It works perfectly on Desktop but in Pro it will only clip to the extent of the layer, not the shape. This gives a square, rather than the shape I want.
Is there an option somwhere that I haven't found yet?
TomBole
Andy,
I'm unaware of any general clipped map / export issue. I was able to get a clipped result exporting to jpg.
Of course there may be something specific about your map, layout rendering, export options, etc... that results in the clip being ignored. Can you contact Esri Support? They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Tom
AndySiegel
New Contributor III
Thanks for the reply Tom. I ran into this problem with export to PDF. I just tested with JPG and PNG, those exports correctly show the clip...so the problem is probably with PDF. I will contact Esri Support and let them know.
Andy
ChrisBehee1
New Contributor II
Hi Andy,  I've got ArcGIS Pro 2.4.1 and still get the export without the clipping being honored for both jpg and pdf formats (300 dpi).
